Help and support
Broadband help
Fix a BT Broadband Problem
What light are you seeing on your hub?
Your device is connecting via WPS mode
Back
BT Home Hub 3 - Flashing Blue Light
Press the WPS (Wi-Fi Protected Setup) button on your computer or device to reconnect it. You must do this within two minutes.
Your hub will return to normal mode after a few minutes.
Need more help?
More options
Ask the BT Community
Contact us
