Back
BT Mobile and tethering
Yes it does. Tethering is where you set up your phone as a personal hotspot so other devices like laptops and tablets can use it to connect to the internet. Here's how to turn tethering on and off for Android phones, Windows phones and iPhones.
Yes. BT Mobile supports tethering, so you can use your phone as a personal hotspot to share data with other devices.
Here's how to turn tethering on and off for Android phones and iPhones.
When you’re using your phone as a personal hotspot, you’re using the monthly data allowance that's on your mobile plan. So make sure that you have enough data left each month before tethering your devices. To avoid unexpected bills, we also recommend turning off your personal hotspot when you’re not using it.
Don't forget, you can set up a Spend Cap to stop you from going over your monthly allowance.
Find out more about Spend Caps
Tethering works on any Android phone that has the 2.2 Froyo operating system or later. Android phones are all slightly different, but generally this is how you set tethering up.
  1. Go to your phone's main menu and look for Settings
  2. Look for Wireless & Networks, then Tethering & portable hotspot
    Setting up tethering on an Android phone
  3. Switch on Portable Wi-Fi hotspot
  4. Go in to Set up Wi-Fi hotspot
  5. Give your phone's hotspot a name and set up a password. You can then use these details to connect your other devices, just like logging in to any other wi-fi hotspot
Turning tethering off
  1. Click on your Android phone's Menu
  2. Look for Settings and click on Wireless & Networks
  3. Then click on Portable WiFi hotspot to switch tethering off
  1. For tethering to work on an iPhone you need to have the latest version of iOS. Go to your phone's menu and look for Settings, then General, then Software update to see if you're on the latest version. If not, follow the on-screen instructions to update your phone
  2. If you're on the latest iOS version, go back to Settings
  3. Tap the Personal Hotspot option
    Setting up tethering on an iPhone
  4. Tap the Wi-Fi Password option. Give your phone's hotspot a name and set up a password. You can then use these details to connect your other devices, just like logging in to any other wi-fi hotspot
  5. Tap Done to continue
  6. Switch "Personal Hotspot" from OFF to ON
Thanks for your feedback
Submit
