Fix BT Mobile problems
I've got a problem with my SIM -
Understanding charges Understand your BT Mobile charges. Learn what you’re billed for, why costs may vary, and how to manage your usage and avoid unexpected charges.
How do I report a lost or stolen phone from abroad? Don't worry. If your phone is lost or stolen while you're abroad just contact us.
I've got a problem using BT Mobile abroad Fix any problems you have using your phone abroad and find out what to do if your phone's been damaged, lost or stolen.
Problem with a BT Mobile order Help if you have issues with your mobile delivery or need to order a replacement SIM.
Track your mobile repair Use our interactive tool to track the progress of your mobile's repair
Using 4G Calling Discover how to use 4G Calling on BT Mobile. Learn what it is, how it works, when it’s available, and why it’s included in your plan.
Fix Wi-Fi Calling issues Having trouble with Wi-Fi Calling on BT Mobile? Learn how to fix common issues, check settings, and get your calls working over Wi-Fi.
Fix problems using EE WiFi Fix problems using EE WiFi hotspots with your BT Mobile.
Go back to: Mobile help
