Back
Reset and pair your EE TV remote
The EE TV Box Pro remote pairs with your EE TV Box Pro or Edge Box over Bluetooth
Resetting your remote
Resetting your BT remote can fix software glitches and reset factory settings, which is useful if you've made and accidental change.
To reset your remote:
  1. Press the Home and 9 buttons at the same time.
  2. Hold down the buttons until the LED around the BT icon flashes purple three times.
Pairing your remote
Pairing your BT remote to your TV box lets you control power, volume, navigation, searching and channel selection.
To pair your remote:
  1. Press the Home and 7 button at the same time.
Thanks for your feedback
Submit
Need more help?
