Here's what to do when you've previously connected to a BT WiFi hotspot, and want to switch back to your BT Hub.
Here are some answers to help you
Why do my devices keep connecting to BT WiFi instead of my BT Hub? -
I have problems connecting 5GHz and dual band devices wirelessly to the BT Hub See how to solve the problem caused by dual band devices not coping with single log-in details
Connect to a BT Hub using wi-fi Discover how to connect to the internet on different devices wirelessly, after you have set up your router with BT - follow our useful guide.
How do I connect my device to my BT Hub by Ethernet cable? Connecting to your BT Hub with wires gives you the fastest and most reliable broadband connection.
Go back to: What type of connection problem are you having?
