Back
About BT Hub Manager
If your Wi-Fi isn't reaching every room, Hub Manager lets you check and adjust your settings. It makes it even easier to manage your Hub's settings and to get the best Wi-Fi setup for your home. It's also easy to see the Hub Manager on all devices.
Access your Hub with BT Hub Manager
  1. Open a new web browser.
  2. Type 192.168.1.254 or type http://bthomehub.home into the address bar.
  3. This will open the Hub Manager.
  4. If you want to make any changes to the hub settings, you'll need the admin password. You'll find it on the back of the Hub if you haven't updated it.
Using the BT Hub Manager
Use the links to find out more about how you use the Hub Manager to change settings:
Smart Setup
What is Smart Setup on the BT Hub? How can I turn it on and off?
Hub lights
What do the lights on my BT Hub mean?
How do I dim the light on my BT Hub?
Admin password
Where do I find the default admin password for my BT Hub?
How can I set up or change the admin password on my BT Hub?
Access control
How do I use BT Access Controls?
How do I turn off BT Access Controls for a device?
Wireless functions
What is the wireless mode feature on my BT Hub?
How do I see which of my BT Hub's wireless bands my device is connected to?
How do I turn wireless on and off on the BT Hub?
What is the Smart Wireless feature in my BT Hub?
I have problems connecting 5GHz and dual-band devices wirelessly to the BT Hub
How do I split my BT Hub's SSID (wireless network name)?
Port forwarding
How do I set up port forwarding on my BT Hub?
Still need help?
For more advice on how to get the best from your BT Hub, visit Help for Hubs
Or, if you’ve got one of our older Hubs, why not buy our latest BT Hub?
Thanks for your feedback
Submit
