Back
Digital Voice
Here are some answers to help you
  • What is Digital Voice and how can I get it?
    Digital Voice is our new home phone service for the next generation and beyond. Delivered through your broadband connection, it gives you an improved service and crystal-clear calls.
  • Moving to Digital Voice
    If you're moving to Digital Voice, you'll be upgraded to a new broadband-based home phone connection. Find out more about the switchover and your new equipment.
  • Set up your Digital Voice service
    Learn how to set up your BT Digital Voice service, including connecting your hub, handset and what to expect when your phone line switches.
  • Set up a Battery Back Up
    This article covers setting up and using a Battery Back Up, which can power your BT Smart Hub and Openreach modem so you can still make essential calls using the Digital Voice service.
  • Set up and use a Digital Voice Adapter
    This article explains how to set up and use a Digital Voice Adapter for your Digital Voice service. The adapter enables you to set up your handset wherever it suits you best in your home.
  • Using calling features
    How to manage Digital Voice calling features such as Voicemail, BT Call Protect, Call Display, Call Waiting, and more, with video and written help.
  • Call Protect for Digital Voice
    The Digital Voice service comes with Call Protect, which detects and blocks spam and fraud calls, without blocking your important calls.
  • Call Waiting for Digital Voice
    Call Waiting alerts you when other callers are trying to reach you. You'll hear a discreet beep when someone's trying to get through to you while you're on the phone.
  • Call Diversion for Digital Voice
    Call Diversion lets you divert your calls to almost any phone, including your mobile. Call Diversion can also divert calls while your phone line is in use.
  • Withholding your phone number
    Withholding your telephone number means that it won’t be available to the person you’re calling, here are the steps to follow for a temporary or permanent solution.
  • Migrating contacts
    As a Digital Voice customer, your phone contacts are stored on your hub. So, if you're getting a new hub, you'll need to back up your contacts and restore them onto your new hub.
  • Problems with my service
    This page has quick links to answers to the most common problems you may have with the Digital Voice service. These problems include making and receiving calls, or problems with your phone or extensions.
  • Problems with my calls
    This article will help you resolve issues with calls on your Digital Voice service with step-by-step advice for the most common problems.
Thanks for your feedback
Submit
