Review the step-by-step instructions in our device guides.
Here's how to change APN settings on an iPhone.
- Go to Settings
- Select General
- Select About
The "Carrier" should show as BT with the current version greater or equal to 18.1
If the Carrier is not showing "BT 18.1":
- Go to Settings
- Select General
- Select Reset
- Select Reset Network Settings
