As an EE TV customer you have more viewing choice than ever with NOW.
NOW is available via monthly membership you can add or remove at any time. Watch on your EE TV box where you can record and pause your favourite shows, as well as on smartphones, tablets or gaming consoles via the NOW app.
Get general information about managing your BT account >
Managing your NOW Membership on your EE TV package
NOW is available via monhtly membership. You can add options or remove your membership at any time by logging into My BT, or if you're an EE broadband customer with EE TV, log into the My EE App, or call us on 0800 956 6000.
Cancelling NOW Membership
Your NOW Membership will automatically renew each month. If you don’t want this, you cancel via My BT or by calling us on 0800 956 6000. Any changes you make will take effect at the end of the 30-day period, so once you’ve cancelled an add-on you’ll be able to keep watching until then. No refunds will be given.
Managing your NOW devices
The NOW app is compatible with hundreds of devices including smartphones, tablets, Smart TVs and games consoles. You can install the NOW app on multiple devices, but you can only register it on six at the same time.
You can watch two devices at the same time, if you're watching on a EE TV Box, you'll need to leave NOW channels to start watching on the App. Then you can go back to watching NOW on your EE TV Box too.
If you're watching on two EE TV Boxes then you can start them in any order.
If you have NOW Boost or the HD add-on, you watch on up to 3 devices at the same time.
Find out what devices NOW is installed on in My BT.
Adding or removing devices
If NOW is registered on the maximum number of devices, you can remove one or more via My BT .
You can make up to three changes a month.
Renaming devices
If NOW is installed on two similar devices - perhaps you have two smartphones of the same model - it can be confusing. To make it easier to tell the difference you can rename your devices in My BT .
If you forget your NOW username and password
It’s easy to reset your log-in details by heading to the NOW dedicated page:
Changing your NOW email address
To change the email associated with your NOW Membership, you’ll need to contact NOW by visiting the My Account page or using NOW's echat service.
Moving home
If you move home you’ll be able to continue watching NOW using the app on your devices. Once your broadband and EE TV is set-up, you’ll be able to watch NOW on your EE TV box.
Cancelling EE TV
If you cancel your EE TV package, all the NOW shows that are included in your plan will finish on the day your EE TV contract ends. Any NOW passes you have will be available to watch until your next renewal date.
Update your billing address
You can change your contact details using My BT.
