Back
Buttons and sockets on the Openreach fibre modem
The Openreach fibre modem has been specifically designed to work with our fibre-optic network.
If you have Fibre to the Home, have a look at Fibre to the Home: Check your wiring and set-up for information about your modem.
Otherwise, click on the equipment that matches what you have at home to get the right advice:
  Select this if your modem looks like this: Openreach fibre modem
Select this if your modem looks like one of the below:
Openreach fibre modem Openreach fibre modem
Thanks for your feedback
Submit
