Back
All about Call Barring
Call Barring lets you stop certain types of calls from being made from your phone. You can also use it to bar all incoming calls. All BT Digital Voice features are free of charge (excluding premium voicemail).
How do I get it?
You can easily add or remove Calling Features online
How do I use Call Barring?
Barring all calls to your phone
Barring *261#
Cancelling #261#
Checking *#261#
Barring all calls from your phone
Barring *34code#
Cancelling #34code*PIN#
Checking *#34#
Codes
1 Bar almost all calls, including Voicemail – cancelling this option also cancels any other options you’ve barred
2† Bar national and international calls and calls to mobiles
3† Bar international calls
4 Bar all operator calls, e.g. 118 500, BT Text (SMS text messages) and BT Text Direct 18001 & 18002.
5 Bar calls to numbers with a *or # in them (includes some Calling Features, but allows you to cancel this option)
7 Bar calls to Premium Rate numbers.
† For customers on certain exchanges, this option will also bar premium rate services. After selecting this option, if you find that calls to premium rate services are blocked and you would like them to be unblocked, please call 0330 123 4150. If you have a fibre phone service, this will Bar international calls and calls to mobiles and Premium Rate numbers.
Calls to messaging services using 1571 can be barred under outgoing call barring code 1, this is because calling 1571 may lead to a chargeable call. It is also essential to remember that calls can be made via an operator unless they are barred with code 4.
Calls that are never barred
  • 999 Emergency services
  • 112 Emergency services
  • 150 BT residential customer services
  • 151 BT residential fault reporting
  • 152 BT business customer services
  • 154 BT Business fault reporting
  • 144 BT chargecard
  • 0800 free numbers
  • 0500 free numbers
You can still accept reverse charge calls when you have barred calls from your phone. You and others in your household can connect to barred calls via the operator unless you have used code 4.
Our Calling Features guide provides instructions on how to use it.
Calling Feartures user guide (PDF)
Thanks for your feedback
Submit
Need more help?
