Back
BT Smart Hub 2
BT Smart Hub 2
This article provides all the information and help needed for the BT Smart Hub 2, including physical descriptions of the device and its ports, support for Wi-Fi settings and the Hub Manager feature, and compliance information.
What's in the box
image of a power supply brick and cord
Image of a paper user guide
image of safety instructions leaflet
The power supply
User guide - you can also download a copy at the bottom of this page.
Safety instructions leaflet
Full Fibre connections (FTTP)
An Ethernet cable
Part Fibre Connections (FTTC)
Broadband cable
Part Fibre connections (FTTC)
A filter
Physical description of the device
  Broadband port
This port may not be present if you have a Full Fibre (FTTP) connection.
Thanks for your feedback
Submit
